You do realise that's a hyphen, used for annotation and connecting related sentences - the character will only work as a minus/negative if it appears before a number...and even then...you can't leave a space between the minus and the number...
If you can drink alcohol, you can have the pork.
and, its not a flash bang per se, because this does have explosive power..
Alawites differ from average Muslims, I explained this last time.
Muslim is Muslim man.
theres the ones that are like, youre not muslim you die.
theres the ones that are like youre not muslim so ill avoid you
and theres the ones that are like oh youre jewish? lets go have a drink and lol at the others stupidity.
I have a feeling my default wins of best r32 gtst will now be challenged...
Need to get my shit in order now
to avoid persecution now, you ned to adopt some other things.
but 6 generations being brought up to not eat bacon, i think ill hold off. even though i know nothing will happen if i do eat it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
