You do realise that's a hyphen, used for annotation and connecting related sentences - the character will only work as a minus/negative if it appears before a number...and even then...you can't leave a space between the minus and the number...
If you can drink alcohol, you can have the pork.
and, its not a flash bang per se, because this does have explosive power..
Alawites differ from average Muslims, I explained this last time.
Muslim is Muslim man.
theres the ones that are like, youre not muslim you die.
theres the ones that are like youre not muslim so ill avoid you
and theres the ones that are like oh youre jewish? lets go have a drink and lol at the others stupidity.
I have a feeling my default wins of best r32 gtst will now be challenged...
Need to get my shit in order now
to avoid persecution now, you ned to adopt some other things.
but 6 generations being brought up to not eat bacon, i think ill hold off. even though i know nothing will happen if i do eat it.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
