Bluefire grill waterfront docklands
Not bad
All you can eat when you're not even hungry = shame
Soccer + motogp on tv = win
lol <3 Bluefire, they hassle you non-stop until you flip that card over. Go there on a Tuesday, I think it's half price then.
My friend put a multi-bet on the Italy Croatia match...Pirlo to score the first goal and the game to finish in a draw...$5 x 90-1 lucky f**k!
Shout out to Hamish.
Food at Chin Chin was awesome, flavours and textures were great. 'Feed me' option my stomach was about to burst. Dessert was the highlight of the night, think it was a coconut ice-cream with honeycomb.
chin chin means penis in some language.
Any of you ever had the chance to try Warthog? Take the tenderness and juiciness of the best fillet steak you've had and times by 10. Omfg soooooo delicious. I've actually lost my appetite for other red meats after that. Had it last weekend in Zimbabwe and not sure if anyone imports it but I'm gonna find out! Bonus was the three course meal for my bro and I only cost $75 best!
Nismo engine/gearbox mounts or Factory mounts?
The stiffer Nismo mounts create more vibration through the body of the car, not sure if its something i'd like in the car... More vibrations = more rattles
Anyone running Nismo mounts?
I was very unimpressed but then my first try of brazilan BBQ was in rio, sooo much better!
nah, it took 3 years of 300rwkw on a 200,000 km motor before i managed to snap my mounts....
replaced them with new oem ones when the new engine went in
bluefire was good value
~$50 p/p for the all you can eat menu including drinks (on a friday)
just under $60 with desserts
was annoying, they should just put the meat on the table and go away instead of coming over every 2 minutes "would you like some more?" ofcourse i want some fkn more wtf do you think!
lol yeah i lost $100 to my brother and $50 to a mate over that game :/
btw does your bike have a display that tells you what gear you're in?
but you forget, these engine mounts have to live with the power of the mighty rb20 :P
Although the factory engine mounts cost more than the Nismo mounts, ill get the factory ones for comfort....
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
