Old school jap shit puts it over anything.
Alex do you like dragons?
because dad sold the family business =D
liquidated. yo.
hahaha, my old will sell if he gets enough for it
some of the suppliers want it and keep asking but are being tight about it even thought they are multi millionaires and he doesn't even want much lol
Nah I got those ones you didn't like lol. You mad?
can't remember what they were, so not mad....... yet
Dad is getting old, crashed his car. I think he had a minor heart attack or something mum told me his chest was hurting last night.
Stubborn prick still went to work instead of doc's
What a way to start the day
shit dude :( get him to see doc asap
just waiting for my grand dad to liquidate the drug company.
Sorry to hear Aaron, hope he pulls up okay.
Lol nick those kranzes look like something you can buy from bob Jane, if you like them that's you're choice, but yeah nah, they do nothing for me.
Maybe because ecu thinks car is in cold mode and running rich? Your 30deg water temps can't be good lol
Touche' Pat.
Cold temps I guess are better than what it used to run at. Really hot during summer, 130c oil temps then my radiator exploded and water in the engine boiling for 1/2 an hour lol
Just a few extra dollars at the pump all good!
Getting really bad fuel economy, as the car is running really rich since changing to a massive radiator.
I lol'd. Have you tried replacing oxygen sensor? They are ~$100 and usually net you another 60-70km out of a tank if it's a worn component. Faulty O^2 will cause it to run rich when cruising around.
no shit. my dad calls me at 7 last night and sez he's gonna be late coming home from work and to tell some dude that he was expecting to visit that he'll take a raincheck. cool cool. so i head out to play some indoor. check my phone after (11pm) and find like 20 billion missed calls from mum. apparently, he had fin work at 4, gone to the docs and was ambo'd to the hospital. they admitted him and held him there for 6hrs then sent him home. first thing he did when he got home was to fill up a glass with scotch. by the time i get home he's passed out drunk on the couch.
for added context, he's had a major heart attack last year.
I'll give it a look when I get the chance.
Just having a feeling its just due to having a really cool radiator, as it was when changing just the radiator that my fuel economy went worse.
them old schoolers make our generation look like a bunch of pansies
my dad's messed up with the flu, can barely breath with a f**ked up back injury yet i wake up at 6.40am and he's already waiting outside ready to go to work eventhough he's his own boss!
work addicts.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
