On another note, ever since I swapped in my standard airbox I'd lost 50-60km per tank of fuel and felt a little down on power. Swapped my pod back in and it's all sweet again. It was tuned with the pod on, but I thought pod vs airbox was supposed to make SFA difference besides sound. Also, Ric is running more power with the standard airbox...you done any mods to the airbox Ric?
Interesting mr birds, I haven't done back to back test between pod and stock air box myself, but was told the same by sfa of difference.
What kind of filter in your stock air box by any chance?
Makes my blood boil those kids should be smacked around severely and the parents as respect starts at home & school
I look at the government schools around my area the kids are all oxygen theives I just know my tax will be paying for there sorry existence when I was at school all sir/mrs stand up when principal came into the room even just basic uniform policy that was enforced is good foundations
Much work to fit the GTR bov? I'm running 16psi and it doesn't always happen, only when the throttle plate slams shut on a fast gear change.
crossover pipe bolts on perfectly but the return pipe is a larger diameter than gtst. the gtr return hose ID is almost the same as the gtst return hose OD. i mcguyver'd it by slipping the gtst hose inside the gtr one and cable ties but would not reccommend cos it makes a horrible honking vibration on partial boost
Cheers Basti, will give it a shot.
P.S. An online charity was set up to support elderly woman and it looks like she'll be getting 100k from it...bit ridiculous but she definitely deserves something after that.
Nah man, bog stock. I remember we took off the snorkel and the lid on the dyno and it made negligible difference. Never had a pod so can't compare.
That sucks though, I'd love a bit more power and better economy lol
This is what happens when parents don't smack their kids. Disgraceful.
http://www.youtube.com/watch?v=bJ9n8JQJy2c
lucky you can't really see kids faces (only one shortly) because they would get knocked the f**k out if people saw them
I really want to right now myself
Dad is getting old, crashed his car. I think he had a minor heart attack or something mum told me his chest was hurting last night.
Stubborn prick still went to work instead of doc's
What a way to start the day
no shit. my dad calls me at 7 last night and sez he's gonna be late coming home from work and to tell some dude that he was expecting to visit that he'll take a raincheck. cool cool. so i head out to play some indoor. check my phone after (11pm) and find like 20 billion missed calls from mum. apparently, he had fin work at 4, gone to the docs and was ambo'd to the hospital. they admitted him and held him there for 6hrs then sent him home. first thing he did when he got home was to fill up a glass with scotch. by the time i get home he's passed out drunk on the couch.
for added context, he's had a major heart attack last year.
our dad's should hang out
Anyone know the boost limits of the standard R33 GTS-T bov? Starting to get compressor surge at high boost.
had mine up at 2 bar with no fails (although that could have contributed to the motor failing lol)
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
