come past tullamarine on sunday?
ajay and neni are coming to check out the car. bring an LM :) lol
yeah maybe, I'm having a go-karting sesh sunday morning at South Moorang, so it is kinda on the way lol
ayo dezzmang/ other old schoolers.
you guys know a dude that had a 32 gtst + s2 rb25 on here from fawkner named colin? hes a ranga lol
hes on sw, knows all the old school sauers
No one comes to mind....'Cln' maybe?
Don't remember meeting any wasteland rangas...
owner of charspeed* (forget companys exact name, they do body kits etc here in melb) asked me to detail his r35 on the weekend :blush: also told me he is picking up an 86 tomorrow...
oh and he had a new honda jazz with a supercharger bolted on when he came into work today..
lol wow
lol wow
Is your car really shiny lol? Any recent pics?
lol wow
Need a hand detailing the R35 GTR?
Grats on taking the plunge...at least one of us had the guts to lol. How is it for head height? How tall are you? Engine give adequate power? Might come past on sat for a look.
Head height is fine, pretty sure we were similar height. Engine could use a little more, but for the time being its enough.
Till supercharger
sell to me
Nah
fell asleep and missed the auction lol
send another attack helicopter and ill consider it <3
yahoo newb
yeah I bought the rb20 box off him when he upgraded to 25, although I never met him in person was at the workshop that was doing the conversion
ahah not at the moment it isnt!
ive been meaning to take some pics for a while man :(
i need to give it another decent claying and a really deep cut
to be honest i want a respray done in the same colour LP2 midnight purple, lol though doubt ill be able to afford that for along time!
I may!
lol not sure ill be able to this weekend though, and if i cant he will be in HK for the next 3 weeks :/
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
