3rd and final group certificate acquired. Come at me 1198S
Hahaha doooo iiiiit :D
Am I going to get flamed if I say I prefer the Duc 999
The 999 is a good looking bike.
-_- you said you preferred the RSV4 to the 1198 shape.
seriously how much do the 1198's sell for?
we sold a repo'd one for like $8k
done about 3,000km. perfect condition.
They range from about $20-$25k second hand, but the market isn't moving so cheaper is possible.
$8k... phwoar.
What are some of the prices that the cars are selling for?
it depends on who's at the auction man.
if a car doesnt meet the reserve, and fails at an auction, then only after that im able to privately sell.
as an example(not factual figures) a c63 new ranges at around $180,000 drive away(including finance and stuff +say 30% interest)
we sold one that was a 2011 face lifted model c63 amg done 12,xxx k's full service hist, rwc, 1 year rego blah blah blah, for about $110,000
40 guest viewers again wtf? Get your union cronies out of here Dezzeye.
I call bullshit on your memory.
It was the 1098 we were comparing to the RSV4, not that there's much difference; I do prefer the RSV4.
RSV4 > 1098/1198 > 999
Knew you'd have my back. Takes me back to high school; sharing earbuds at the bus stop.
Just noticed how purple Dre looks in your avatar; blends in with the SAU Vic tags.
lol ok. you do realise vehicles that sell at an auction sell for substantially less than a private sale. let alone a dealership. Birds your in the business trade industry you should know that.
Used to have dealers buy cars for me at the auctions and yes, they do go for substantially less than private sale. But substantial being enough to make a tidy profit on the vehicle, not a ridiculous margin. Don't doubt the real bargains happen from time to time with no reserve auctions, but finding it difficult to believe that a 20k-25k bike in near new condition would sell for 8k, even at dealer auctions. I'd wanna see the papers!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
