Friend took on the hoggs breath challenge in ballarat. 1.1kg steak. Signed the empty plate and it is on the wall now. 3rd largest steak to be consumed in the place.
Beat it Dezz?
I would rape 1.1 kg.
hot?
also how much tax back do you get back on donations normally
/taxlinesaustralia
Average
Beat it Dezz?
Some monsters on here, I'm a small eater. Can't compete with you brahs
Beat it Dezz?
Time limit? Sides?
I did the 1kg challenge at outback jacks, but foolishly did it for lunch on a day when I wasn't feeling particularly hungry/good.... Smashed the 1kg steak without any hassle in about 15 minutes, leaving 15 minutes for the sides...but that's what got me...
I'd ordered the 500g rump there a few weeks before, which came with chips and coleslaw... So I assumed the 1kg rump in the challenge came with the same sides....But instead it came with around 500g of wedges and 500g of vegies...
at the end of the 30 minutes I had a few wedges left and a few veggies, so on a good day I think I could knock it over.
Hogs breath steak is even more tender so that'd make it a lot easier...Most of the time is spent chewing the steak...
Time limit? Sides?
yeah came with sides. Not sure what sides or time. Will find out one day. omnomnom
On another note; just chipped in for a friends birthday present :D
Just drove from the city to Flinders to care for my horses, 1km from my house I get pulled over. Car has been defected. Bald tyres.
Could have been worse.... Much much much much much much much much worse. Cop apparently knows my family and had done the fencing on our farm when I was young so fortunately his attitude was forgiving. Stuck the defect on then took photos with his iPhone saying 'it's not every day you get to defect a Merc' I had to laugh. Phew.
I need to get back to the track :(
lol!
Birds and I just came back from a ride.. down eastlink bike track :D pretty big lols when some guy was riding a push bike.. also lol @ the evo
Martin I'm a member so I can see :P and no I wont be donating my engine to a r32
damn it need to be registered.
but short of it is:
5.0L Miami Motor in Nissan Skyline R32 4 door - Track only.
Sweet Jesus. I want it.gonna sign up to see.
Lol at tattoo bitch. Anyone ever come close to tatting something like that? Not so much a face but yeah.
lol!
Funniest shit I've seen in ages man. Could not stop laughing at pushbike vigilante...did you hear him ringing his bell at us lol? Was wondering where that path finished up...casually exit path onto road again ftw.
Evo driver was a little bitch; only wanted to do rollings. I think once he stopped at the lights and saw what he was taking on, he didn't bother - did he follow you down Terrara?
f**k that shit, I came up with a tatt I wanted at 16....at 30+ and still wanted the same design I went with it
small, not visible at work, and every time I see it I like it more.
So happy
that said bloody addictive, started coming up with more that I wanted the next day.
that said the one I came up with the next day I still want 3 years later, so might do it as well.
once again will be very very non visible at work.
ok so on a random side point. ie cars.
I have a hankering to see what I can do down the 1/4 mile. I hit up calder the weekend after I got my car and never since.
was on pathetic rubber and way down on power.
any-one know what the Calder off street days are like now?
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
