Notice given - time to cruise carsales
Didn't you just ask for a pay rise?
Although I do like the look of the R1.. very much so.
$7500
May as well have printed AIDS on the front, that is f**king hideous.
lol dezz and Leigh get R1s
/R1saustralia
Seriously though, love my bike...wouldn't trade it for much, only a top level Duc or a big cruiser if I got sick of sports bikes. You'd be very happy with one, they are just extreme.
another question
Solid mounts: yes or nor(reasons supporting why not)
taking it you talking engine/gearbox mounts?
I moved from the OEM to the nismo "solid" mounts when had the engine out.
Engione def has less movement which I assume is a good thing for the drive train
best point isgearbox moves less so you have much more confidence in where the gear leaver is.
b4 them leave in gear hit boost and it porb moved an inch or so, now just MM.
mates S15 was ever better it was soo sloppy b4 gear leaver would be moving a couple inches when hit boost or lift off, he went same and cleaned up nicely
Yeh so you reccomend.. Is the car uncomfortable to drive with the mounts or as normal? Coz they aren't exactly solid they are just nismo poly urethane right?
Reason I wanted to as I saw it on the dyno and the motor moves a shit load, then Scott was trying tighten the wastegate and as he was pushing against it the whole motor moved. Don't know if fkd or just how it is but I didn't like it. How do you rate 'Megan' stuff? $250 +ship for engine and gearbox mounts, they are pretty much the nismo ones with a different brand stuck onto it
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
