Notice given - time to cruise carsales
Didn't you just ask for a pay rise?
Although I do like the look of the R1.. very much so.
$7500
May as well have printed AIDS on the front, that is f**king hideous.
lol dezz and Leigh get R1s
/R1saustralia
Seriously though, love my bike...wouldn't trade it for much, only a top level Duc or a big cruiser if I got sick of sports bikes. You'd be very happy with one, they are just extreme.
another question
Solid mounts: yes or nor(reasons supporting why not)
taking it you talking engine/gearbox mounts?
I moved from the OEM to the nismo "solid" mounts when had the engine out.
Engione def has less movement which I assume is a good thing for the drive train
best point isgearbox moves less so you have much more confidence in where the gear leaver is.
b4 them leave in gear hit boost and it porb moved an inch or so, now just MM.
mates S15 was ever better it was soo sloppy b4 gear leaver would be moving a couple inches when hit boost or lift off, he went same and cleaned up nicely
Yeh so you reccomend.. Is the car uncomfortable to drive with the mounts or as normal? Coz they aren't exactly solid they are just nismo poly urethane right?
Reason I wanted to as I saw it on the dyno and the motor moves a shit load, then Scott was trying tighten the wastegate and as he was pushing against it the whole motor moved. Don't know if fkd or just how it is but I didn't like it. How do you rate 'Megan' stuff? $250 +ship for engine and gearbox mounts, they are pretty much the nismo ones with a different brand stuck onto it
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
