mine is fine.. maybe you broke something?
Nah nothing. Everything went straight in according to Scott car drives fine. Just idle lol.
They arent nismo they are megan ones. But essentially the same. Maybe I shouldve just gone nismo
Kinda off topic, kinda not....I would like to If I may talk clutches.....
what are ppl using thesedays? With what power, usage of vehicle and longevity?
I would like some recommendations please....but not of extreme....as it appears my years of support of them and my purchase of many(probably around 6 id recon) clutches still doesnt deem me important enough of a response from them....so they can shove it.....(this is the 2nd time I"ve contacted them with null response....grrrrr end rant)
Does anyone have the hookups for clutches at a better price? Its been so long since I've been in the trade now...wahhh retail hurts..
Want me to bump the idle up a bit? Perhaps its harmonics at that idle speed?
I heard something banging underneath the front too when you took off, perhaps the cooler pipe? Could you be feeling that through the wheel somehow?
I'm running an exedy HD organic, not huge power 180-190 rwkw but lasted me near on 3 years of track use so pretty happy with that.
Haha enjoy.
What do you reckon of the new marv creations? Popping candy and jelly bits.
Popping candy tasted good, though I'm guessing it's targeted at kids as pop rocks usually are. The jelly one got stuck in my teeth hard lol, ruined a pod block of chocolate for me...but my mate loved it so meh. I love mousse too, but can't beat the classics sometimes. Do you guys do Top Deck in bar form?
NPC
/topic
Cooler pipe could be right to some extent seeing as the engine has moved a little.. But I doubt that much. Drive it tonight when I come past
At the moment, I have the Nissan GTR clutch but Racepace will be strengthening it to handle 300+ rwkW.
Or go an Exedy or Nismo Coppermix.
On The Run Motorsport could help you out.
A friend of mine ordered off RHD Japan's website, take a look.
Did you pop your motor? What's planned for it?
I'm using the Nismo Super Coppermix twin plate. Great clutch which can handle a heap of power (400+kw) and it feels like your using a standard clutch.
spoke to jamie at garage cafe one of his pistons was knocking or something, he's getting it rebuilt (forgies) with -5s or similar
Think he wanted -9's. Were trying to convince him to go -5's to make use of his built engine, we'll see if he will succumb to the powah!
But nah -9's great for the street!
Hey Toby accounting question -
Is there a downside to buying a car outright (cash) I mean I know you won't claim interest etc but that's fine cos you don't have to pay it in the first place.
So im guessing the only negative is that you don't have the leverege that keeping the cash at your disposal provides
Does that make sense?
Edited by alr33x
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
