I understand the rocking up to work bit, I use to feel a bit weird when people stared / greased me off in my old car still that wasn't the main reason I sold it I just couldn't be f**ked with the cop stress around Knox and as you said got over driving it.
Whats the chances of a work car? wouldn't they let you know when you started?
dem rims: what are they?
Yeh should be getting one soon but haven't been made aware of when it's quite annoying
No stamp duty between spouses - everyone else gets reemed by the long arm of the sro
Pretty sure that's the rules.
Wasn't given ya shit brah was just answering a question..
Fwiw stamp duty will be way more than 10k
no offence taken dude lol. i just didnt ask the question as hamish said, if stamp duty is all I really have to pay to put the house in my name - it kind of(sort of) cancels out what was already paid by current tennants..right? in any case not fussed, if dad decides to keep it its not like I've made such a lost that i'd need to go bankrupt.
go bug them for it.
well part of it that my probation goes for 6 months(as per germany) and that finished on the 26th of this mont. so will bug them then.
on another note, ive now taken on the Remarketing side of ALL of our repossessions, and doing all the valuations and oversee each car/truck/van/etc that comes in.
and doing Vendor stuff through pickles/manheim/greys etc interesting to say the least.
I wonder if I enter the nats this year what cars I'll come up against in the standard rwd class, if Nissans are running anything other than oem turbo then that's counted as modified class? I might be able to win some trophies :D
Dynamic Performance Engineering (DPE) Wheels.
The Porsche was supplied / owned by Vogue Auto Design (VAD) but had RWB Japan to work its signature wide-body customisation to it.
Well standard RWD class in the SAU VIC Motorsport champsionship you can highflow but only one of injectors, fuel pump.
So pretty limited to ~230rwkw anyway.
Have fun with your trophy lol
Thats what I thought lol, skylines will be easy to beat but wondering if anything else is going to challenge? (for airport anyway)
Definitely need some NT05s by then though
You going up?
You going up?
I might need to buy some NT05's soon too. Pending on how the Invo's hold up with the new turbo
Nah don't think i'll be able to make it this year
depending on how you drive is dependant on how the invo's hold up.
but definitely better times will come out of better tyres.
no longer a daily then?
Still a daily, as I have no other car lol
Yeah will see how it goes when I install the turbo, May need to feed the throttle out of corners when I track it
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
