Forgets myki at home, has to spend $16 for another. I want paper metcards back...
I don't want to always keep a plastic card in wallet for the rare chance I have to catch public transport...
$16?!
And no more metcard?
In London, they have a thing called oyster and it works and they also have paper ticket for whoever doesn't use it everyday.
Why can't it be same here? This we won't know.
Speaking of Alvin, I turned his wagyu mince into a kg of spaghetti.
Will report back with taste. Already noticed it clumps more than regular mince and has less "juice" to drain.
$16?!
Yeah it's like $6 for the card and minimum $10 top up. No paper metcards from the stations i believe.
Oyster works in london cause everyone catches the train. Not here where you have people travelling from suburbs into the city :/
Cool vid. Have a soft spot for rx7s
same, I would of probably owned one by now if the motors were more reliable
http://www.ebay.com....#ht_1218wt_1163
if only the fronts were more aggressive
woweee
http://www.ebay.com.au/itm/19-Work-Meister-S1R-Rims-wheels-JDM-Pirelli-Achilles-Tyres-/320974007125?pt=AU_Car_Parts_Accessories&hash=item4abb8aab55#ht_542wt_1397
Flared and an extra 2 degrees or so. Yum. Sank you aaron. Mind you, the guard in pic was flared by hand. LOL. Honda quality
Have u had it aligned? Looks like the drivers sticks out more. When's it's all aligned bring it round so I can even it out, plus I need to redo the passenger side to get rid of the lip
Fuuuuuu
Waved into a booze bus which came out of no where. Pass the breath test, "pull over to the side please and pop the bonnet"
Asks me if car modified, say nup apart from exhaust. Looks at engine bay. Not helping my statement with a 52mm alloy rad, thermofan controller with led's and air pod lol.
Shines torch over engine bay, then looks at front tyres and reads the Japanese tyre placard.
Says all good and let's me off.
Thank god for staggered fitment. Rears would have been too wide.
Haven't had a cop encounter for 2 years lawl.
/csb
Allignment tomorrow. Left pic is previous (before flare) aaron, right is after.
Theres more camber on passenger, i think i'll get the right side set to the same. But I have a feeling the drivers is flared out more.
The shape of the guard is way better on passenger (the one you did by hand) Flows better with bumper.
Been taking like 1 per day.. only because I hadn't been working out for a week due to some stitches in my chest from a small op I should try and get onto it twice a day if I can withstand the smell / chunkies :P
I'm doing 2 scoops not 3 so guessing around 4-5grams of creatine with the mass gainer then taking pure creatine around twice a day (5 grams again) I should be doing it 3 times a day though considering it's my "loading phase"
Currently around 75KGs getting there slowly, I was under 70 when I started
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
