Finish doing my reps of 100kg bench, feel pretty boss...Maori guy on the bench next to me does 130kg x 12-13, bar moves like it has no weight on it and he doesn't even breathe.
I do 65-70 at home :( okay.jpg
I swear my bar is harder than a gym because its so f*kn long (my brothers mate gave us the bar, i wonder why haha) half the battle is balance ever my brother struggles with it at home a bit for some reason lol maybe I should increase that shit force dem muscles to learn.
Also, leaving tomorrow for DECA at 9:30 I'm driving my car up now so if you wanna come with I can give you a lift in style brah. (this invite goes to anyone in SE) I always end up doing massive power skids down the DECA road after watching the pan hehe.
I should have entered DECA this weekend! I just wanna do some laps so I can see how well she takes corners.
Come and enter haunted hills
Give it some time and you'll be benching heaps
Yeah hopefully I can increase it up a bit more soon, I'm still only a small guy but just been starting the creatine which has helped me out a fair bit I reckon
Guessing Rimon does like 130 lol
Longer bar = easier to balance unless you got a serious bias. But you'll have balance issues with any bar on bench, it's a free weight exercise and part of it is strengthening your core with trying to balance the bar. Keep at it, it's a tough exercise to step up in, probably the toughest. Lots of people can deadlift and squat heaps but suffer when it comes to bench.
Sounds like a good offer. Would have come but got friends 21st tomorrow :(
That red Ford looks like a hot wheels toy car.. Do not want
Just got home from a mates... Took princes hwy for a bit... Highway chase! Lol! HWP lights on screaming after a bike... And then passed backup and a lurker (going in the opp direction... Maybe to catch if he does some hectix u turn...).
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
