cant, the rears would look silly as plus I need 19s because I'll be doing a 6pot brembo upgrade at some stage down the track
also, STRAYA KANT.
How much will this set you back?
How big are the rotors on your car out of curiosity?
I don't get the re agents and cocaine reference, but anyway I'm unashamedly a fan of iPhone and almost every business is working towards it and being compatible
Not hating on Samsung or whoever never tried it but as they say if it ain't broke don't fix it
I used to think phones were the best, even after putting up with it constantly crashing and it not syncing music like it's supposed to
Then I got an S3
Lol iphone.
So the s3 is good? Full review please. I'll consider buying your bike
Reading this right now.
Always find the Motor Tuner challenge intradasting
Sub $75k cateogry dominated by 86's and Golf's
Would have been more interesting if they did it on a bigger handling track. I.e. winton or something
They're the only reason I buy Motor otherwise I wouldn't bother buying/browse it at all.
86/BRZ and Golfs seems to be next budget 'Tuner' cars.
You can get a front brembo 6pot kit with braided lines and brackets for just a tad over 2k for my car
322mm stock rotors on the GS, brembo kit comes with 355mm rotors
Straight from a review of the GS:
Braking: With the same brakes as the XR8 (322mm and 302mm discs, sliding calipers), the 315kW GS is under-braked in our view, even as an entry model.
Feel through the pedal is soft, making it poorly matched to the ability of the engine. A shame, then, that the GT's four-piston Brembos are no longer an option on the GS.
Basically they didn't allow brembo factory upgrades because then you would be getting a GT for 15-20k less.. engine and everything else is the same only difference is the "315" and "335" tune which goes out the window anyway now that mines tuned to what? 440kw? lol
Then I got an S3
Lol iphone.
Was that 3? My 4 has been only phone to last me 2 years with zero problems I use my phone flat out to
fyp
LOL!
also, STRAYA KANT.
Agreed with the haters on iPhones.. all the f**king smart phones these days have big touch screens, take photos and have 'apps' zomg soooo different!! apple is too mainstream? I don't care because my car has integrated iPhone connectivity so I can have everything display on my screen in the car and use steering wheel to change tracks etc. If I had an Android I'd have to plug it into the 'AUX' connection and use the phone itself to change tracks.. that alone is enough for me to go Apple really.
And same as what Alvin said with the Ipad wifi model, just use my phone for reception if I'm out and abut.
Oh and Hamish you're right about the customer service / replacement phones, pretty good. I used them a fair bit at my old work.
Stick to ya Bob Jane wheels :rofl: STRAYA KANT
Android for the fucking win! KANT!
That actually seems quite cheap
link?
Newsagent brah
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
