Any of you engineering students doing mechanical engineering?
i think downshift is doing mechanical.
jonoe does civil.
kaitoukid does process aka chemical eng.
Hehe nah bro; I do aerospace! There's a fair amount of cross-over with mechanical, as you can imagine, though.
nah nothing like that...
he got the car painted ford xr5 orange and we all told him he'd cop a defect from the first cop that saw him....
he drove it out of the panel shop (DT and before he was even out of that little side street.... BOOM! first cop that saw the orange defected him!
touch f**king wood then! but my car hardly see's road anyway. i have a missus that takes me everywhere lol
LOL! Video link?
lol its on his phone.. looks like the same mistake i made at sandown
faster, faster .... CORNER FAAAAAAAARRKKKKK
lol
Bike is more economical than I thought. Quicker than a 911 turbo, I thrashed it for the whole tank and it still delivered 7L/100km...umad car owners?
no... the money i save in hospital bills will easily outweigh your petrol savings
LOL! @ the Volvo too!
lol
Hah!
I think he miss-judged the corner or braked too late.
Nick I expect an invitation when you get those beauties
For sure man, I got a box of 25 so nearly half will go for my cousins buck's weekend and have 14 left over (hopefully :P)
the other 20 are to try for my next order, two of each so me and my bro will finish those ;)
ah nice they'd go down pretty fkn sweet with some good scotch
need to find some cohibas for new years eve
U gonna be rich
False.
There is no aerospace design industry in Australia. There is Boeing in pt melb but that is just a manufacturing wing. Designs come from America.
Apply for mech jobs and hr will knock you back as they want mech eng not aerospace.
Have couple friends who did aerospace. Had a real hard time finding jobs.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
