been told its the most beautiful city in the world by more than one person..
i haven't been but definitely want to!
I can safely say it's way better than Paris, as for other cities, yeah it's strangely beautiful that I can't quite work it out. You'll need to head over there to see for yourself.
When my parents went there, they said the same I thought otherwise until I went there.
Cool we have decided to go as part ofour wurotrip next year.
Must see sights??
Astronomical clock - if you head there on Saturday or Sunday you might gate crash a Wedding as it's on a church.
Charles Bridge.
Old Prague and New Prague - basically 2 era of Prague divided by river, one modern and one old fashioned, you get the idea.
Prague Castle.
'Hunger' wall - short walk from Prague Castle.
Jewish cemetery - not quite why it's a must see attractions but I was told it's quite important bit of history in Prague by receptionist in my hotel.
Freedom steps, same area as 'Hunger' wall.
That's it off my head, pretty sure these all I've been to, and I'm sure there's more. There's a weird clock on the hillside alongside Prague Castle that I struggle to remember the name of it.
/martinstraveladvice.jpg
ill look after you, just don't buy crappy brand items, please for the love of god.
haah nah the grills alone are going to be costing upwards of 8k each i believe :)
It's not being done on the cheap
outside my house in a quiet area in newport.
that said area becoming less quiet, been ehre for 7 years and laty going down hill, neighbors had their car stolen earlier this year for some prick to get home, (was torched in altona north)
will move to bigger place next year further out so I can work on my cars myself.
My plan to purchase new bike gear today has not gone to plan, damn having to find a helmet that works whether I'm wearing contacts or glasses.
Now can't go look at a bike either, fek
Hmm, last time I bought a helmet I found I didn't have a shoei shaped head.
Even tried one of those flip front ones... couldn't get it on with my glasses on, could put my glasses on after it was on...
um yeah, I always take glasses off to put helmet on
glasses cost way too much to risk.
plus that how helmets are designed.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
