I dunno - leigh said it I was just expressing my surprise.
Really though gettin a ban is a badge of honor therefore I salute you birds!
Lol I got banned for suggesting we have shans beloved dog stuffed so he can keep it for ever...
so worth it
Need a haircut :/
Get one to look pretty for Garage Cafe
got a haircut yesterday. need to have it fixed today. not being able to see without glasses ftl
I know that feel bro
niroj get lasik, shit works well.
$money$
$money$
$5.5k, might be able to claim some back on tax?
for me though.. worth it considering i'd spend like $600 every 3 years on new glasses because I needed some special lenses or something.. had glasses since I was 6 feelsgoodman to not have them anymore for the first few months I'd still wake up in the morning searching for them before realizing.. oh wait I dont need them
I didn't really care about any appearance changes was more the fact that my eyes were so bad was just shit going to the beach / swimming / theme park rides / motorbike helmet / cleaning the list goes on shit having to take them off and on all the time and they get in the way.. not having to worry about it now is a great life changer for me
Yesp can claim on tax
Yeah glasses are annoying, will consider laser eye surgery in the future
Oh add watching 3d movies to the list of annoying shit with glasses /firstworldproblems
Tony I suggest getting your eyes scanned a little in advance so they can re-scan a year on to check for any changes (I had to wait like 3 years due to my eyes still growing / changing)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
