Headquarters (southwharf) location. On 6th floor overlooking docklands.
Doesn't hurt to go through the interview process anyways :P
Yeah PM me the details, can't hurt to take a look. Half the appeal was the idea of it being around the corner from my house though haha :(
Cheers
Damn you Martin
Mmmmmm VB...
Better stock up my fridge.
Martin when is Bathurst on?
bathurst is 4-7 oct so not this weekend the one after.
no cancelling trips, I scheduled my last few for the year for after this.
singapore, thailand Philippine's and HK to go.
Position available for internal communications advisor.
Responsibilities include publishing daily corporate news on intranet, writing quarterly newsletters, manage communications, corporate video production etc.
Requirements;
Good verbal and writing skills, print and video production processes, basic idea of photoshop, project management.
If interested, shoot me a Pm.
Sounds like a fun job
So a glorified PA by the sound of it.
45k pa?
All roles are glorified by their job descriptions these days, consultant/engineer/manager get thrown around so much they've lost all meaning. At least this one is specific about the tasks, instead of misleading with some title like "account manager" so the applicant only finds out after they've signed on that they are the new paper shredder.
Even director doesn't mean shit anymore, outside the legal sense of it...
45k pa?
unsure of wage, thats negotiated based on your experience.
Call it whatever you want, any job can be simplified and undermined but im not going to encourage such childish behavior.
Best to think about the positives; be it a foot in a door, easy job in the city or chance to explore what fits.
Agreed the term 'engineer' gets thrown around a lot in I.T :\
Jonoe is comin with to nats la
very true I'm a Fire sprinkler fitter and at trade school its called Fire Protection engineers hahah i feel bad for the actual engineers that do years of uni to get that title
haha ive resorted to calling my self a professional engineer. I do recall an Engineering society challenging the use of the title but got denied due to its overuse in the market.
You are also a top bloke, so why don't you call yourself that?
Fireworks. NAOW
thought i'd give 5th gear another shot... .(after being turned off by all the presenters not named Tiff..)
First story....
FIRST FUCKING STORY
and that stupid woman is giggling and screaming
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
