Look like quite a bit of entertainment here last night.
Will need to organise some time of UFC Cage Fight for the Show N Shine
Pat v Ashrey
Moh V Dezz
Birds v Aaron
ill take on Leigh because were both bulkers
Everyone too scared of me huh?
as a rough guide, use the online caculator that most insurance comapnies have.
put in your details prior get quote
put in same details but tick one claim, see cost.
won;t be %100 accurate but close enough
Cheers for the idea Marty but Justcar insurance can't do online quotes for Stags... :yucky:
btw, such nice weather today!
I'm stuck in a climate controlled factory with no windows. It could be the apocalypse outside and would not see/ or feel it. And any chance for stepping out during a break isn't possible as I'm wearing factory uniform :(
What do you do for a job, again?
Bond, James Bond
Must feel good on 40c days brah
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
