Tony, you know the drill when you've sorted the power department...
Man, I need more power! 270rwkw isn't enough, haha.
Not sure?
We race lol?
Or you drive my car I drive your car again :P? Though yours is a little precious this time around!
Amazing what you can find out with a bit of digging isn't it? :D
Have similar such methods for dealing with SAU scammers & other things. Funny thing is that most of them simply are not that intelligent to begin with so information can come thick and fast on occassion.
I tell people sometimes just to google their own name/phone number. It's hilarious sometimes how much stuff is returned as a result.
you should see the shit I have access to in regards to tracking people down... late stage mortgage collections brah, we find everyone eventualy...
Do a track day at Winton
Pretty much nothing to crash into
Or just drive slow like me so you can't crash into anything :P
really, last time I saw you @ DECA it was too much :whistling:
Why ruin the fun? :( Don't think everyone will forget this, damnit.
tony, why don't you have a chat to jono about there being nothing to crash into @ winton ;)
I mentioned that last night.
imo white on white only looks goo when it's the same colour of white
that looks shit cause its a different shade
Yeah true, the different shade ruin the look.
But if done right, it's all good!
Yah, still a fair way away though.
Going from your sig... SHITE! That's a long wait!
Should have just bought the Toyota version.
I know you hate the sales people at Toyota but could you have gone to another Toyota dealer?
Ill take it, would like to keep my varex for the next car! Sent u a pm ill pick it up tonight if that's cool
hey i asked first!!!
but then i realised it was an exhaust component and not something to shoot stuff out of, so i'm not interested anymore.
You could use it to shoot stuff out?
Ha! You don't need it your exhaust is big enough lol
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
