gay..
rockford subs and amps.
warmer sound.
stronger more stable bass.
Not according to the car audiophiles/workshops & various awards
W6 line of JL car subwoofers are renowned for their SQ and pretty sure they have won many awards with that line of subwoofer.
This was 2-3 years ago but I'm sure the same still applies
Just sayin
Just sayin
I was referring to the alpine range.. Although I'm not really a fan of JL audio either..
Especially the type r splits and co ax.. Never liked them at all. I really like the original MB Quart and the now German meistro. They are fkn awesome. I don't car what any JB hifi sales assistant says.
Fk especially hooked up with the Rockford 360.
Man memories of sitting In the car for hours tuning with the laptop
I dig my Type R splits. You do have to stage them properly though - not speakers you can really be facing away from. My Type S sub does alright for what it is too, anymore and my 17 year old car would rattle to pieces.
JL amps are very good value for money. They made a name for a reason!
I'm pretty sure they basically made a knock off of JBL audio lol..
And me being an OCD audio guy, I can't stand the poor projection of the alpine range especially the harshness of them.. I can understand the value for money thing, but poor sound actually gives me a headache. You can blame mark for making me notice thing I probably would never have noticed before lol
I don't think Alpine count as value for money, except for maybe Type S stuff. They are more "get what you pay for" and sit in the medium cost range. It's not high end stuff but it's no JB HiFi combo sale package either. Fortunately all my gear came with my car.
If I was doing a system again in a decent car I'd hit up Boston/Rockford/Focal. Do it once do it properly!
/audiolinesaustralia (cwatididthere?)
Yeh that aswell, but why would you spend money on good support for shit speakers?
Being in audio you figure out how to make everything sound it's best. Whatever the position or setup be, or limited to..
Plus the better the speaker in most cases the less you have to worry about volume measured boxes or ported.. Or even the position they're in.
6x9 should never have been invented. Waste of time and money. The ones in my car annoyed me so much that I unplugged them lol
But focal/Rockford/German meistro.. All these you really don't have to worry about the position as they project substantially better than alpine shit.
My opinion anyway everyone likes different tunes, I prefer the warmer sound, where some actually like the middy sort of stuff.
I believe you get a lot better sound per dollar value in spending on setup than speaker models.
Put in the research and time and your average speaker models could sound as good as your higher end models if their setup is done poorly.
I've recently built a decware deathbox II enclosure. Haven't tested it yet though. However it's all wired up.
Anyone have a 1ohm stable amp for me to test?
I have a feeling mine might be 1ohm stable....
Will need to check, I used to be into car audio a few years go but not anymore. I can't even remember the model of the amp :/
At the moment its 1200wrms @ 2ohm for my sub
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
