There's not been any details released as yet. I've already added the rear diffuser to my order, so out of that list I think I'd add the 'Front Under Spoiler'/front diffuser, 'Side Under Spoiler'/side skirts, and 'boot lip spoiler' as they become available. I love factory parts. Wheels, coilovers and braces I'll go aftermarket.
I see!
The subtle factory add on kits usually look quite good.
And yeah, Wheels / Suspension / Strut Brace go aftermarket.
i wont be buying an 8MR.. no chance ill afford one lol
this is my dilemma... VIII's go from 20k and VIII MR's from 30k.
EOTD i'll probably go an VIII with an IX or VIII MR turbo already in it
only thing i'm thinking is that the MR may hold it's price better? i dunno
Can I also be there for joy ride pls
alright, probably tonight or tomorrow night good for you?
Toby, take me for a spin while you have it, pretty please?
Happy to take whoever on a spin, maybe tomorrow night.Not till late though don't normally finish up dinner till after 8:30. If its a few guys prefer it on the weekend.
Yup definately holding its price. My brother got his for about $35k five years ago. And its still in really good condition
And if 8MR's are still 30K plus its held up really well
Some sub-30K IX's as well from memory, last time I checked carsales...
Awesome :D. *clears studying schedule for these more important things*
Edited by kaitoukid
the only difference between them is the alloy roof and turbo i think.. so kind of pointless to get an MR when you could probably get a turbo out of one for cheap..
im even considering a seven! i think the bodykits on the seven are heaps better.. and i really dont wanna mod it too much.
If you plan on modifying then no point getting an 8mr only advantage it has is an alloy roof and not paying $10k for that
$10K for an alloy roof?
What's the roof made of on the non MR Edition?
IX turbo, lower intercooler pipes, injectors, ebc, tune... 230 awkw done
coilovers rims etc... obviously
yeh, same as my thought..
7's are apparently good up to 245kw
so im thinkin of e85.. just a tad safer.
lead
BOV, gear-knob and seats are also different... ;)
8MR has no value over an 8 for a street / track car. Spend $10k on mods for an 8.
The 6 Speed box on the > VIII models eats the VII 5 Speed is the only consideration. The gearing is far far better.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
