have had experience firsthand with the effect of appearing professional. pettet both times, hoodie/trackies/unshaven vs straight outta compton hospital with shirt/tie/hospital nametag etc. difference in his approach was like night and day
Normally $2 a can which is more than tuna costs, so....actuallytastesgoodman.jpg
Admittedly haven't had it straight from a can - my toasted sandwiches usually do a good job of covering up the fishy taste of tuna, so they could have done the same thing here. But they did taste better than tuna sandwiches. Similar protein levels too...give it a go.
You mean he was slightly less of a top bloke when you dressed well? Must have a hard on for the rough types.
Your work in a hospital?
These are $1 at Coles. Thought I'd try some as a substitute for tuna in my toasted sandwiches.
Bread (Toasted)
Garlic Butter
Chicken
Grilled / Melted Cheese on top.
Makes it taste better.
I remember we spoke of this at the last Garage Cafe SAU meet :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
