That's the front
One of my mates cars, currently for sale too
Thing is awesome in person :)
he got it from JPN front and rear 9 with the mivec head and all.
didn't believe him initially that it was a 7
Shit that's a lot of work to be done to do a mivec conversion, that's a awesome car
Engine I presume was rebuilt too?
graphically the main thing deterring me from a 7 was the lights...
with this new info I might just go a 7 and be happy with 220kw odd
Always a fix for cosmetics brah
7s are great.
though at 20k, i'm not sure its good bang for buck.
If you plan on modding bang for buck they become a lot cheaper than a skyline though
about $2k-$2.5k will net you a stock evo to 230ish kw
That's full exhaust, licp, bigger turbo, remapped, ebc and can probably even budget cams in there if you get the exhaust cheap enough
$5k will get you to 300awkw
EVO 7 with EVO 8 / 9 Spoiler?
Yeh but runs the 9 rear bar so looks good cause it matches :)
EVO 7 with EVO 8 / 9 Spoiler / Rear Bar?
and headlights/fin thingy on the roof..
also skirt CF extensions, different front lip, and diffuser extension on the rear bar.
not much really to get it looking like that.
oh thats awesome.
lol not kaitou.. i meant emts.
Sure, sure
I'm just hoping I can get a clean 8 for 17-18ish Christmas next year.
Lol exactly what I'm hoping for as well (perhaps a bit after Christmas also fine). Not sure how likely this hope is, though :S
Yeah.. initial outlay is high..
And i've been thinking about it since last year. Still thinking.
no idea on rebuild was only running around the 240ish IIRC
dont think the work that huge.
Mate just did a MIVEC conversion on his 8MR not super cheap but cheaper than a lit of other mods
boosted his mid range very nicely
do ittttt :P
well I guess it's more for cost and sourcing parts
you need to rewire the whole mivec wiring into the ecu as well
and the head alone is at least $1500 plus wiring
i seriously have no idea why you sold yours.
I do regret it a lot, however at the time I was sick of imports. As a matter of fact I'm still pretty sick of them
Golf gets attention, but not the bad kind and it sits at about 50mm off the ground and has no exhaust :P
also a lot cheap. but fwd gaaaaaaaaaaaay..
though 18km/L makes up for it.
haha that's through town on freeway i get 23 to 25km/l
depending on road incline etc, but usually hangs around 4-4.5 litres per 100km :P
yeh.. im not expecting the evo to be the greatest, but anything would be better than the silvia and its 250km to a full tank lol
expect around 300-350max around suburbs, the small tank is a killer
also they do drink being so responsive :P
well thats fine from a 40 litre tank.
stagea was a 80 litre tank and i was getting max 290km from e85(granted its ethanol)
hmm
I get around 450 around town 600+ on freeway..
lol 270 kw is a very tempting power figure.
and i never did freeway or long distances..
Good to see it's all interchangeable!
lol @ comparing ethanol with PULP on consumptioin
hence why I put in brackets granted its ethanol.
if it wasnt such a risk to do it with the seven rods, i would be tuning on e85 this weekend.
the servo is a 5-10 minute walk from my house lol
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
