What'd you make Toby?
Guy in an excel was driving behind me this afternoon, taking a photo of my car on his phone. Were u mirin me Dezz?
Yes
Took a photo once while driving of a sticker advertising 'hectik' hairdressing but couldn't get a clear shot...was disappointed.
How much for a men's cut?
Corolla, 400km+ a tank... :rofl:
That it...?
Staying in Hamilton. Wanted to try Royal Mail but schedule does not allow :(
Next time!
Went for dinner once - around 8... "Let me check, the kitchen is about to close" ffs, damn country towns
Toothbrush cleaning the engine bay - found a split in the tiny hose out of cyl 1 manifold position to the charcoal cannister..... pulled the spark plug all good on the colour.... gotta love/hate the map sensor based ecu otherwise would have been running like a bag of shit sooner.... think it's been split since I bought.
Fixed hose....PLUS - moooooooore boost earlier - goes well.
