I warned him before he bought them lol. He said nah, I got good luck since putting them on.. Lol
Poor alwina
beats having a 32R disappear on you
That said, this is what the defect notice says.
1. Air cleaner - to be secured
2. Rear wheels, to be covered to axle height.
no rwc required.
Will cable tie down the pod, and also, put on the wheels off the v35 on.
He tried to tell me my car needs Z rated tyres. like reary?
So fingers crossed, when the epa comes, its just noise, i know its not possible, but a man can hope.
thought you said semi's....
RS-R def not semi's
It's weird, half the places I look advertise them as semi slicks, but they look like (and have the specs of) like... extreme performance tyres. Either way, bang for buck it looks like they're what I'm after :)
Yeh they are pretty good tyres, they screech abit but like Martin said. Not semi.. Borderline though
as a general rule, semi is lower than 100-120 wear rating
rs-r are 140,
my R888's are street legal so it not like that a hard thing.
o rly?
im looking at getting semi's sometime next year, so will be doing some research then.
Edit: can anyone recommend a decent place for interior detailing? south/east regions
o rly?
yeah msot sold in AU are, RE55's R888 A048's
all street legal.
plus my R888's were cheaper than my RS-R's i had b4!
o rly?
immaculate reflections?
lol
no rwc required.
If he saw the bleed valve then that's a full EPA. The same goes for intercooler an airpod.
Vicroads staff don't know what bleed valve is. They will look at wheels and pod and go back.
all street legal.
Where does one acquire cheap R888's.?
I better tape up my bleed valve with black tape once my tuned is finished then :ninja:
Coming to GC tomorrow night Pat?
If you've got the stock airbox, you can tuck it under there pretty nicely as well. Makes it super hidden.
That's pretty cheap!
Still a bit more than I wanted to spend on DECA and a few track days.
$240 fitted for a 265/35/18 595RS-R
vs
$730/2=$365 unfitted,unshipped for a 265/35/18 R888
Different league of tyre I know, but for my level of competition... its a bit more than I was willing to spend this time around, considering I just bought a grand worth of rims as well :( Wallet hates me enough already.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
