Mower, pfffftttt, don't be ridiculous... 48cc Whipper Snipper does the job....
Farkin girl...
I use a hammer and Phillips head screwdriver to shave my chest these days.
What's the best stuff to spray on my rear bar to keep off exhaust discolouration?
Is there a product that makes life easier for me?
meguires ultimate compound to get it off. Then meguires ultimate detailer spray (forget it's name but the new version of quick detailer) farken good
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
