one step ahead of single guys in not being whipped?
aaron pls
birds is not only whipped by one person, but 3... lol ULLTTRA WHIPPED
bitch pls
lol I've been in and out of relationships and arrangements, never been whipped by a girl whether single or taken. Black knight motherf**ker.
Aaron pls
I call bullshit
wigga pls
twilight getting pretty good...
aaron pls
Let me elaborate;
The only reason it was getting good was because peoples heads were getting ripped off and graphically seperated and the main actors were dying and i thought "this is great, means there wont be another one" which means I wont be forced into going..
then it was a "vision" and I thought
Aaron pls, this shit will never end.
Dandenong is as close to 10mins from the CBD as Niroj is to white.
people were saying its not in dandenong, but i didnt suss out where exactly. thats why i stuck to Melb and not CBD. Melb is pretty big. yet there are still housing issues :(
*cant find a new rental that suits his needs*
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
