Nah roof is high enough should be ok
I'd be more worried about cutting the hole under a joist...
Have fun with the plaster dust lol
Yeah gotta get up in the roof and sus out the positioning first...
Feel free to PM me with how you'd go about it all....I think I've got it worked out but first hand experience is king
Dezz I reckon the older style tail lights look much better might look into modding that in down the track and relocating indicators problem is most of the kits on ebay have the crazy illegal number plate positions lol
Should pick it up tomorrow if it passes rwc okay
Edited by UNR33L
Yep, more cops rocked up after bunch of emos left. Might been you and your friends?
And cops blocked 3 exits, 2 on same street and one towards Jersey Rd.
4 cop cars, 3 UC and one HWP.
lol nah i was gonna stay and watch, not having a defectable car is fun, but samir and daniel wanted out because of theirs so i left...
made it better when people were doing skids in front of the hwy patrol.
sif not say hi grant..
lol I should have stopped by, would have loved to see some f**kin tools doing burnouts copping a yellow sticker and a f**k off fine.
Saw Tone at Cold Rock though :)
Sorry!
Mike and me watched for a while then I decided to bail while we have the chance.
What did you wanted to sell?
yeah, I reckon it looks heaps better above the exhaust
Already done mine... just waiting for my exhaust to arrive so I can complete the fender elimination and install the new indicators. Will look sick when it's finished
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
