Thanks for the spoiler jackass^
They both are side missions which I wasn't aware of either. So doesn't ruin the experience.
Finding trixie is one of the objectives. Traitor I'm not too sure what he means?
Re-do the mission and talk to the NPC's.
Sargent would have explained the traitor after the mission, from your first round.
Am I gonna need a different tow hook setup for my 33 for Sandown? If I do need a tow, my front bar is gonna get destroyed right?
I'm assuming its one of the Support Navara things with a towbar strap and a carbina on it?
Your car is already falling apart so, broken bumper will be least of your worries :P
3 weeks worth of WL read...that's a couple hours not getting back...
Haha. I'd personally wouldn't get my car washed there, detailed yes, the guy's real good, trained the guys at waxit. but not washed. Some of the things the guys do there bro, i'd be pissed off. Its a lot better than the magic hand ones though.
When they need to do a proper job, they'll do it (regular customer thats picky or whatnot), but most of the time its care free.
If you come in, i'll make sure its done properly :P
corner williamstown rd x francis street
how much discount..I live just up the rd.
yeh apparently 30% smaller, and the video quality, 1080p 60fps. even if it comes after, its well worth the wait..
will be good to use in fiji aswell, hopefully going parasailing if im not too fat for it LOL
when Fiji? where staying?
Just did Parasaliling in Boracay..scuba much more fun.
Who's good with computer viruses
I'm not shabby, which ones you want?
don't crash it easier..
only a few days, 30th Jan - Feb 3rd.. No Idea where staying, the missus has organised it with her dad, he owns a couple of apartments up there in some building.. mainly to go see her Grandma whos ill.. but yeh wanna do scuba, but cant imagine myself in a wetsuit.. beached... Also her cousins have access to some jet skis up there.. will do that too!
Toby when you upgrade?
LOL
Yeah all I'm gonna do is laugh...not at Hamish...but at someone buying a car with more power than they can handle and not treating it with respect, assuming that's what happened. Hopefully he wasn't insured so he can learn a nice long lesson from it...
How'd you find out about it Ham?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
