f*k i'm getting better at parking close to poles aye. I have to park next to a pole. And when I do, if i drive straight, mirror will just scrape the pole. Haha. Too many careless kids and people who slam doors.
I park next to a pole nearly every time. Only had one instance where I wasn't paying enough attention and the wheel arches on the Cube stick out a fair way from the body. Lucky I had the flares.
Mine were genuine too..
And birds it does no negative harm to have heat range 7's
Not harm, but takes longer for the spark plugs to reach optimal running temperature...when you're driving a daily on short trips it makes a difference. Always go as hot as you can without overheating - just like injectors, going as small as you can without running too much duty cycle.
Essentially, I could park our straight piped, externally gated S15 track car outside Knox police station...that short, fat asshole can write a Tom Clancy novel of defects for it...and then proceed to shove the whole notebook up his own ass using his tears as lubricant.
Cars have been defected on Trader Plates. So yeah, you kinda couldn't :P
I ran 7's on my SR20. Wasn't the greatest idea for a car being moved short distances occasionally. Would foul a set beyond use in 1000km's.
i was happy to sit on the limiter on a 40c day at DECA with a trent tune and never managed to get the light on....
jus sayin ;)
Btw I see you may have found 'da 1' e7 pending a check over ;)
:ninja: :ninja: :ninja:
Noice.
Edited by kaitoukid
If his name isn't Sven or Hans, you're being ripped off.
haha probably is I've just never asked :P
They are apparently well audi / vw / BMW
Hmm, still not sure man. I go to VolksHome in Thomastown because it's close to me
holy jeebize id love one but i dont think i could handle a bear haha
Nah those are big males, our female is much smaller
Dog or bear?
Nick would say Dog but its clearly a bear/beast id love to have this bad boy guarding the GTR but the fact that there bigger then me worries me
Yeah dog, although they do have a really strange smell about them that isn't dog at all
i've got a cat. feed, and ignore.
I prefer cats, I wasn't a big fan of dogs until we got Mechka though. She is the best with who know her
That's why I recommend 6s, particularly if you have a conservative/rich tune. Stock engines run 5s okay...no reason anything this side of 300rwkw can't deal with 6s for daily duties with a thrashing here and there.
Noice.
reading evolutionoz forums eh?
yeah, everything set to go as long as the compression holds up and there is no rust / structural damage
Fair point. I had to run em on the 200, I found at 270 with a four banger, 6 was just too warm
Ooo00000ooo got a link u care to pm me with?
jus sayin ;)
Every car is different :)
Just going from a PFC to a PFC-Pro with identical tune, my knock went up by 15 - wasn't a problem with the tune, just the way the ECU was interpreting the signal, so it would hummmm along at 35 and it was totally fine (where previous it'd never go above 20).
His knock sensor could be picking up a little more noise than yours did. Either way 65 knock isn't great, but it's still not bad. Anything over 35-70 usually just means there is 1-2 cells that need attention. Misfiring will also cause the knock sensor to go nuts as well, same as hitting limiters etc.
Odi - wideband won't show you much either as by the time it's leaned off to a point that you'll notice, you've already done the damage (no-one stares @ a gauge when fully up it). Much the same as oil pressure dropping when @ 7000rpm, buy the time you notice/light comes on, the motor is f**ked anyway unless you are setting the ECU up to shut the car down in such a situation via a trigger/value/aux input, which a PFC doesn't have.
I'd suggest having the fuel pressure checked, possible the walbro is faltering now and again, I had one give issues like that 6-7 years ago. However with the misfire could just be a case of a loom/grounding issue. Even voltage supply, so not the coilpacks themselves either. Could also be the CAS playing up intermittently, they have a habit of doing that when they are letting go (you can get another 6-12 months out of them sometimes before they die and the car just wont turn on).
Nissan electricals are a headache :(
you know it :thumbsup:
haha exciting stuff. same as aaron... pm me if links available if you will hehe :P
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
