put some bigger dam tyres on it (245s really?)
245's are fine if your car only weighs <1400
Get some 335's under there... You may have to roll the guards and retract the keel to make them fit, but its possible.
<p>
yeh it gets a nice hold of the trees and barriers
lol
lol pwnt</p>
Pfft Aaron I'd have way over 400 on the happy chasers dyno if I threw it on again! :P
275/35 NT05s are BEEFCAKE soo good can't beleive how much power I can get down compared to stock tyres.. the difference is amazing
wanna go me homie?
that's ghey mang
oh btw.. might need to roll fronts more :s there is a little clip that helps attach the front bar i might try folding that in somehow I think that's where it's hitting
Edited by UNR33L
alright.. coming to sandown on sat?
I can do it then in between laps i guess
$50k car.... reeally wanna do a quick job between laps?
presumabley without a heatgun
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
