ahah i was going to try for a job there actually, I used to work as a duty manager @ a coles and enjoyed it.
ahh sometimes i come in during the night - never know! :P
A ex Coles employee eh?
Is there any jobs you haven't tried yet? :P
hmm wonder if burwood coles is hiring.
Best to wait til school/uni starts, that is when they're hiring depending on how many people leave.
That is what I was told cos I want to move to different section at work.
Yeah I'm very close to choosing a nistune the only thing I don't like about it is you can't run dual fuel maps. What did you run in the 33?
PFC...
TBH the thing about my 33 was the epic torque curve... (2835prosftmfwin) it didn't need more than 300 so i just ran around on 98 most of the time.
if i needed to run e85 i just took the laptop to the servo, took the return line off, idled the car and drained the 98 into a jerry, then filled with e85 and swapped maps.
actually, if i had my time again i'd go a highflow, return flow cooler, clutch, diff and nistune max the hell of everything for a relatively legal 230rwkw and not bother with anything more
Gayyyyyyy
yeh, but 230 kw is eeeeeeeasily enough to skid a gtst and you can spend the remaining coin on trackdays/tires etc
and you can tell hwp to smoke your pole if they EPA you....
incidentally they would probably take you up on the offer too, as they are all a bunch of lonely phaggots....
so you have a cheap, fast car, and a free shame-filled blowjob
:0
exactlly what richo did for years..seemed to work well for him
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
