Bring'em to your wedding yeah!
Your welcome to pickup anybody from my wedding lol
Back home and work tomorrow :(
Got tailored suit to try out at Toby's wedding haha
From Vietnam?
I heard they do allright and are cheap cheap
Maybe ill get one too on my honeymoon
Oh yeah Patty check your facebook PM
From Vietnam?
yeah got 2 made in Vietnam along with tailored shoes.
Need to be dry cleaned as they have been crushed since transport haha
Haven't seen te vid (will when I get home from work) yep, mostly GQ and later GU.
GQ is reasonably cheap depending on engine. TD42 (diesel) and RB30s fetch higher price than TB42 and RD28T (turbo diesel).
After some time on carsales seems that the toyota surf/4runner is the way to go
I found Vietnam had much better quality clothing than Thailand, so I would guess the suits are really good quality?
comes down to what the tailor stocks. I ended up buying super 150 grade wool which is high up in the wool quality game. example; internets says hugo boss suits are 130 grade~
Wise choice, parts are easy to find, if you've got 3ltr, Same engine as 2000-2005 Hilux and Prado, so service parts are easier to come by.
2.4l, think some motor share same belt, filter etc...
Fk going to these places, my tailor flies into Melbourne, takes measurements, goes back to Malaysia and sends the suits back over.
Higher number doesn't always mean better quality, just refers to fineness of the thread. There are plenty of 130 suits that are better quality than super 150, they'll also wear better. If you have a job with a lot of moving around, you don't want to be rocking super 150...feels great and light, but you'll wear it out in no time. I tend to save that grade for special occasion suits, weddings etc.
/suitlinesaustralia
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
