Dont worry brah... I have seen this situation before... you'll get it running again... even if you have to overnight parts from japan
But I don't have my car anymore.
Its sold to import monster lol
I'll jog your memory...
You were reported to have died on 1 May 1994, as a result of your car crashing into a concrete barrier while you were leading the 1994 San Marino Grand Prix at the Autodromo Enzo e Dino Ferrari in Italy.
as a result of your injuries and now crispy brown skin, you decided to hide away from all the attention as a young sri lankan man living in Australia... you adopted the name Aaron, because it was the first name in the book.
From here you continued to live undercover as a simple car enthusiast, however at one fateful sandown trackday, your raw talent simply could not be hidden!
Here you kept up with far more powerful cars including stagea's skylines, ferraris, radicals, zonda's, pagani's and mclarens.
It was at this point that I realised that I am extremely bored at work... and that YOU... MUST... BE... SENNA...
don't forget as I read on jalopnic this week
lost his virginity to a fat Prostitute at age 13..
Senna that is
I beg to differ, I wAs keeping up fine with the 240kw plus cars down the straight at sandown. It's a very under estimated car
Given above 150kph, is when they start to pull away
Even gave Scott a run for is money in the 350kw Stagea. He only pulled away at 120kph.
Hence why he bought one lol
I want to see this first hand. Not saying I don't believe you
Tonight
Your car vs say Simon/Birds
Roll on from say 70km/h. That's about the exit speed at Sandown onto the coming straight
pulled away at 120...so the start of the straight?
who doing 70 on the start there ,
I'm exiting the corner at around 100-110....
was painfull at rexmas,
got out of the corner great full power down the straight,
Chris Madden going past around 50-60 km/h faster...damn that 330kw...
you are different to other amatuer drivers martin
If you were talking about overtaking me on the straight, that's because I was trying my hardest not to let my engine lean out ;)
Really need to fix that...
Edit:
I wonder if that could have been the cause of the lower power figure on the last tune...
Assuming that a single dyno pull in 4th gear doesn't completely suck all the pressure out of the system but only drops it slowly towards the end... So the upper part of my rev range could have been running at say 80% of the fuel pressure it should be running at. If it was consistant, then that would have been included/accounted for in the tune right?
Pulling hard through 2nd / 3rd / 4th was leaning it to the point of misfire / detonation, so not a great feeling on the straight.
I THINK that the Walbro 255 is affected more by a lower voltage source than a stock pump or the bosch 040 that was in there beforehand... So if I wire up a direct feed to it with a relay coming off the ECU wire, it should pump more...
But will it also have a 100% speed whine all of the time instead of varying at Idle speeds? aka, stupidly loud?
I was more so talking about corner speed of that turn before the straight
Me?
Nah blue wrx, told me 230kw. If its false then that would explain it
My GTS-T is currently running it's 252kw safe tune...we can test this "Evo is the fastest car in the world" theory tonight...but I think I know the answer already. Short gearing means SFA in a rolling drag, unless you have a substantially higher redline than me and can carry the gear for longer...it just means I have to drop down a gear to be as short as you, comprende? You get the impression that 4th gear is fast going onto the freeway because it's probably the same ratio as 3rd in a Skyline...nothing Criss Angel about it.
On an unrelated note, there's a golf r that always fangs it past my work every day at about this time... God damn they sound sick on gear change with an exhaust, brrrrraaaaaaa CRACK brrraaaaaaaaaaaaa CRACK brrrrraaaa
That driver should be considerate and yell 'FORE!' before fanging it past your work.
How ironic that you would say that... Look what is across the road from my workplace...
Boss's Porsche Boxster has been hit a few times by stray balls...
https://maps.google.com/maps?q=-37.963638,145.033642&ll=-37.964763,145.032642&spn=0.009744,0.009645&num=1&t=h&z=17
Meh, its only a Boxster...
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
