Dont worry brah... I have seen this situation before... you'll get it running again... even if you have to overnight parts from japan
But I don't have my car anymore.
Its sold to import monster lol
I'll jog your memory...
You were reported to have died on 1 May 1994, as a result of your car crashing into a concrete barrier while you were leading the 1994 San Marino Grand Prix at the Autodromo Enzo e Dino Ferrari in Italy.
as a result of your injuries and now crispy brown skin, you decided to hide away from all the attention as a young sri lankan man living in Australia... you adopted the name Aaron, because it was the first name in the book.
From here you continued to live undercover as a simple car enthusiast, however at one fateful sandown trackday, your raw talent simply could not be hidden!
Here you kept up with far more powerful cars including stagea's skylines, ferraris, radicals, zonda's, pagani's and mclarens.
It was at this point that I realised that I am extremely bored at work... and that YOU... MUST... BE... SENNA...
don't forget as I read on jalopnic this week
lost his virginity to a fat Prostitute at age 13..
Senna that is
I beg to differ, I wAs keeping up fine with the 240kw plus cars down the straight at sandown. It's a very under estimated car
Given above 150kph, is when they start to pull away
Even gave Scott a run for is money in the 350kw Stagea. He only pulled away at 120kph.
Hence why he bought one lol
I want to see this first hand. Not saying I don't believe you
Tonight
Your car vs say Simon/Birds
Roll on from say 70km/h. That's about the exit speed at Sandown onto the coming straight
pulled away at 120...so the start of the straight?
who doing 70 on the start there ,
I'm exiting the corner at around 100-110....
was painfull at rexmas,
got out of the corner great full power down the straight,
Chris Madden going past around 50-60 km/h faster...damn that 330kw...
you are different to other amatuer drivers martin
If you were talking about overtaking me on the straight, that's because I was trying my hardest not to let my engine lean out ;)
Really need to fix that...
Edit:
I wonder if that could have been the cause of the lower power figure on the last tune...
Assuming that a single dyno pull in 4th gear doesn't completely suck all the pressure out of the system but only drops it slowly towards the end... So the upper part of my rev range could have been running at say 80% of the fuel pressure it should be running at. If it was consistant, then that would have been included/accounted for in the tune right?
Pulling hard through 2nd / 3rd / 4th was leaning it to the point of misfire / detonation, so not a great feeling on the straight.
I THINK that the Walbro 255 is affected more by a lower voltage source than a stock pump or the bosch 040 that was in there beforehand... So if I wire up a direct feed to it with a relay coming off the ECU wire, it should pump more...
But will it also have a 100% speed whine all of the time instead of varying at Idle speeds? aka, stupidly loud?
I was more so talking about corner speed of that turn before the straight
Me?
Nah blue wrx, told me 230kw. If its false then that would explain it
My GTS-T is currently running it's 252kw safe tune...we can test this "Evo is the fastest car in the world" theory tonight...but I think I know the answer already. Short gearing means SFA in a rolling drag, unless you have a substantially higher redline than me and can carry the gear for longer...it just means I have to drop down a gear to be as short as you, comprende? You get the impression that 4th gear is fast going onto the freeway because it's probably the same ratio as 3rd in a Skyline...nothing Criss Angel about it.
On an unrelated note, there's a golf r that always fangs it past my work every day at about this time... God damn they sound sick on gear change with an exhaust, brrrrraaaaaaa CRACK brrraaaaaaaaaaaaa CRACK brrrrraaaa
That driver should be considerate and yell 'FORE!' before fanging it past your work.
How ironic that you would say that... Look what is across the road from my workplace...
Boss's Porsche Boxster has been hit a few times by stray balls...
https://maps.google.com/maps?q=-37.963638,145.033642&ll=-37.964763,145.032642&spn=0.009744,0.009645&num=1&t=h&z=17
Meh, its only a Boxster...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
