I was more so talking about corner speed of that turn before the straight
So the tight right left b4 the straight
I'm in top of 2nd so for me that just under 110 (have to cut corner a bit and use heaps of curb on exit)
as soon as I have straighted out of corner I'm into 3rd
then 4th just after the start line
then make a sandwich and check my hair due to lack of acceleration for rest of straight..
haha yeah it was ok, easy to make your's like that though or even better
I'll be more than happy with just that.. Would like to start when I come back from Fiji.
Keeping the car stock? Ain't no body got time for that!
Trying my hardest not to but not fun.
Haha mine was a 3rd-4th pull, so i did not to bad 230awkw against 280rwkw
Also tephra mods ftmfw
Still remember that night
That's me being passenger in the white 34R
Richos cnr speeds according to his videos on that cnr is about 80km/h though :/
It's cheap to get 230awkw, especially if you have full exhaust already
main thing is to get a 8mr or 9 turbo
Standard exhaust still lol. I'm just gonna buy all the shit I need and let it gather dust and do it all at once
Just make sure when you buy an exhaust, buy a good branded one, all the shit ones (front pipe especially) tend to fit really badly or not at all
also this was the catback I ran, sounded really nice and not to loud
http://www.ebay.com.au/itm/Apexi-N1-Evolution-Exhaust-for-EVO-7-8-CT9A-4G63-/380458896342?pt=AU_Car_Parts_Accessories&hash=item58951e0bd6&_uhb=1#ht_842wt_1397
yeah I get the feeling that I'm a little quicker though slower corners, lighter car and less lag due to set up.
high speed tho whole different matter.
if I keep the 7 turbo and do the LICP, x3e exhaust, 8MR bov, 3port and tune how close will i get to 230?
just trying to ascertain how much i'll gain from the spend on the turbo
also for the lICP is it just the hotside that needs doing or both?
Intradasting
You got a vid with data overlay?
Even billywhiz's s14 cnr speed is about 70km/h
New SL is gross, r230 shape ftw
Alex, pics of shoes please! where'd you get them?
Got em from matches which is in uk.. Half price ad free shipping win!
http://www.lyst.com/shoes/dolce-gabbana-velvet-loafers-black/
They reckon 220 with cams. 8mr is only like $350
Is the Time %age gap between you and richo a lot lower on tighter tracks? and higher speed tracks he just blows you away?
Like... Haunted Hills vs PI, lol
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
