HappySliders.com is for sale (Happy Sliders)
Click here to buy HappySliders.com for $2,395
lol should probably get that off my sig. Haven't used that domain for almost 5 years.
I come seeking wasteland advice on a neighborly dispute I'm currently having.
Myself and a friend moved into an apartment about 4 months ago and we noticed that the people who live above us often empty buckets of water onto the floor of their balcony, which quickly seeps through the floor and ends up on our belongings. ($200 barbeque, $300 furniture set & an $800 wooden foosball table imported from Italy.)
There have been a few occasions when we were outside and they have done this and our stuff and ourselves have gotten wet. We have tried to yell out to them to ask them to stop, but here's the catch... They are deaf.
Last night after being out with some friends I came home at about 2am and there was water going everywhere all over our balcony. All of our stuff was getting really soaked. At this point I wrote a note saying "Hello, could you please stop emptying your water onto our balcony? It is damaging our belongings that are below you. Thank you." and put it under their door.
This morning I had a note under my door saying "Hi, sorry, it's our toddler's little pool used during heatwaves. Move your things in a bit! If it was lashing rain, same thing would happen! We only did it twice and we only empty the pool over night so take your things inside or move stuff further."
The thing is it has not been hot for days, our balcony is tiny so we can't move stuff over and I can't take the foosball table apart to fit it through the door every time they decide to empty a pool onto us. I have a feeling that if I try talk to them in person they will ignore us because they are deaf and not very friendly. I have a feeling that if I write another letter explaining I can't simply move our stuff and it has not been wet when it has been lashing rain it may start a cat fight.
How would fellow wastelanders deal with this same situation?
i'd probably draw a dick and balls on a piece of paper and nail it to their door and throw a bucket of water under there
I say ep 2, but I meant ep 12 :P.
I used to watch it before it was cool! /hipster
Best part of when I discovered the show though, was the fact it's while all the other 'main' shows (standard sitcoms) are taking a break
Pisscus under their door (Google it)
Suits. One the greatest shows ever.
And yes its public watchable, its not rude/nude... Just office sexy with a few of the minor characters.
I tried watching Shameless at the gym on the treadmill 24" touchscreen things and it's awkward when you're panting and sweating profusely while watching the Emmy Rossum banging... everyone.
Immature approach: Start a fire on your balcony, high enough that smoke/flames pass through/up onto theirs. The choking/burning will soon make them write a note to you. Then tell them to just move their kiddy pool inside, cause it's only for really cold nights...and hell...if your place caught fire, then theirs would get scorched anyway.
Mature approach: Speak to your body corporate, assuming you have one. Oh and play loud subtitles at 3am, they'll quickly get the hint.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
