hasn't vivian (adrian) turned into such a tosser these days..caravaning around UK learning about local customs..
was much better when he would tell them to sod off then headbutt them.
so true
work wants to pay me monthly now. hooray. credit card here I cometh
How is getting paid monthly a good thing?
its because once upon a time sunkist broke my heart <\3
You guys can make up again this Saturday night
It's not... it's just good for the company as it reduces admin costs
Pretty sure he was being sarcastic, hence the disenchanted hooray at getting a credit card.
Haha so I see, my sarcasm detector wasn't working
must be a great vday.
know the feeling:
but our announced last week.
http://www.zdnet.com...ort-7000010253/
you safe tho?
yeah some people pretty upset here at the moment, ah well
yeah I'm safe
I'm a mechanical engineer.
oh. why you learning SQL for that?
need electrical engineers.
need software engineers :( I'm trying to hire two for my team.
Monthly pay is fine unless your bad with money
this
FKN LOL
this chick at work wants to have more data allowance for her iphone through vodafone...
voda aparently CAN NOT increase the data on the plan to 5gb/month...aparently it's physically impossible
so instead they give her a pocket WIFI modem that has it's own simcard that is on a 4gb/month plan that connects to her phone via bluetooth. the thing is as big as a phone.
I would have fkn RAGED
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
