I guess I'm too normal
It is shit. Harlem shake, as in the dance, was around years ago...why the sudden craze because of a song? People need to find more to do with their time...
U guys just bringing wasteland down :(
sorry brahs, should I get the Lego out for y'all to play with? :laugh:
Happy for you to donate any lego you dont want to Orlando :P
Hahaha I would expect it from GMA..
that would be lame... they would make it lame.
BUT if it was serious news reported in the middle of a story on some sad shit like famine and then BOOM.... would be epic
I'm with birds I just don't get it jumpin around like a retard is entertainment.. man the bar has been lowered
you cant lower something that is already on the ground... just ask the stancewanks guys
Dig a hole and park car in hole.
the American sw/hoonigan shake vid was okay. Mad skid.
but. Aussies do skids better, with added Osama.
thanks for the idea hambo
Edited by ARAB
Tony's wedding I tnink needs to be done
First dance being filmed. Leigh walks into camera view (either foreground or background) wearing helmet or horse head in suit. Does the intro to the buildup. Then everyone jumps in.
End scene.
Scene directed, Toby to deliver now.
End scene.
Well I am the MC. So it can be organized
This. People aren't even dancing good in the videos, just acting like retards. And it's hardly random when you know it's going to happen. Army guys and road workers already did this shit with that Beyonce "Single Ladies" dance and Gangnam Style. Fkin gay.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
