This. You normally upgrade the fuel system capacity when considering an E conversion, which takes care of everything being new...cept the fuel lines (which should be fine as long as they're not crumbling away).
But I has gtr fuel pump :(
Damn it, ethanol tune hey.
Someone tell me how far I can get with 550cc injectors
SO media blasting results:
hmm we need to fit a master cly...lets just hit it with a hammer hard them bog over the dents.
that smooth as rear quater:
quality door:
but when whole rear quaters skins are 56$ it's all fixable...
What brand?
I made it to 330rwkw at 92% duty on nismo 555cc
but most people have run out of flow much lower (thinking nismo 555's are just the 740's painted a different coulour)
Drop am rb26 in an drift on a mountain against some yakuza punk. Do it
lol
you should totally do that man... with the appropriate ethnically diverse group of ambitious 20 somethings it will only take you 1 night including paint!
lol
But then a GTR owner somewhere will be missing his engine...
lol
The best part was ignoring the S15 they could have used instead...
The Mona Lisa if you will...
Also re: the e85 evos, I thought he meant that was happening WITH upgraded 1000cc+ injectors and fuel pump.
Edited by kaitoukid
The only reason the evos pop on e85, is because tuners like to cram timing in downlow.. The rods can't handle to much low end torque..
Burnzy has said out of all the 7's he has tuned on e85 only one popped, because of something completely different.. Ie waste gate or something
glasses are annoying, wake up, can barely see clock / find your phone, have to take them off at the beach / swimming cant look at womens or see mates / throw balls n shit, have to clean them all the time, can't play footy, can't wear sunnies, look like an idiot at 3d movies, can't see shit on roller coasters with no glasses, fog up in shower or heat, can fall off during sex, annoying to get motorbike helmet on, can't take semen to the face, have to get special wider goggles when I was doing motorcross the list goes on, can't motorboat things
Contact Lenses :)
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
