Someone save it for me... actually devastated atm looking at these photos..
http://www.pickles.com.au/damaged/item/-/details/C2001--Nissan--Skyline--Coupe/1252333284
How much they offer wreck to you? Wouldn't mind engine and gearbox
Also can you ask racepace how much to modify rb20 actuator for 17psi? Thanks
They usually have a company drive day around this time so hopefully we get to do one
When you getting your E class for a week...your Mercedes benefits are starting to sound like Mohsen's girlfriends.
9k which I suppose isn't as bad, but still.. when you're earning under 20 a year it's a big hit :(
Long story short, this chassis is a nightmare, you know all those stories you find on the internet of cut and shuts and you go "nahh that never happens, just a couple here and there thats it"... well, yeah. My dumbass fault for not having it checked properly and you wouldn't believe how disappointed in myself I am but the only thing I can do now is find another shell, get it checked by Stateroads and hope for the best, then try and sell a roadworthy 32R and recoup my losses, or keep it and build it insane. Good for my reputation as a mechanic as well huh :P
did you buy it from shan? :P
seriosly though, is there some channel to report the people that sold it to you? as in did they cut and shut it and misrepresent it as a real car?
if not... have you thougt about bashing them and reversing the sale this way? I find this to be a cheap and effective way of getting my point across
Great start to my day, stopped in peak hour traffic on Burwood Highway this morning and chick rams up my arse. ashdk;jlhasljkdhsaljdhlkjasdh :rant::verymad::domokun: Car was booked in tomorrow for a few things to get changed over too. Feckkkkkkk
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
