SO car was written off but not put o the register..seems strange.
Repairable Write off...
Cheaper for just car insurance to do a write off payout than fix it (properly).
Thus why this sale is clearly dodgy, there won't be a lot of change from $9,000 o.n.o. if it was fixed properly.
I think it doesn't have to be on the register if the car's over 15 year old?
That could explain why it isn't on the register...
WOOOOOOTTTTT MY CAR IS READY!
Time to go to the panel beaters and pick it up... Need to get there in under 50 minutes or the place will be shut... Waiting on a taxi to arrive now *impatient*
I've already called him saying I'm interested... Waiting on a call back... Will go and see it on my way home if I can.
Called him again just before... I'm going to go see it tomorrow... with Matt...
Shall record the encounter for the wasteland lulz
So... my car had a camry reverse into the middle of the passenger door.
It went into the AAMI assessment center on Tuesday Morning last week (19th)
It was getting a new door, and bring resprayed at a place Monash Car Center on Princess Hwy
I get the phone call that it ready to come pick up tonight.
Went there to go pick it up and it all looked good. the paint colors matched and all was well.
Car was locked, so couldn't open the door.
Accepted the car, drove it home and on the way I noticed a "few" issues.
They've swapped the inner door panel, speakers, glass, etc into the new door. The tint on the glass is scratched quite badly and is peeling (like inch long sections peeling off)
The power mirror does not function at all.
The power window functions intermittently, I'm thinking a wiring connection issue.
The panel gaps are different from the top to the bottom of the door, it varies by more than 2mm from top to bottom.
Letting the door swing shut by itself, it stops with 10cm to go.
Once fully closed, the top of the window looks to be about 1cm lower than it should be, so it doesn't go into the slot where it should go, instead it hits the bottom of the fat rubber bit.
Honestly, how the f**k can a place f**k it up so much... *sigh*
Gonna call JCI tomorrow and rip a new arsehole out of this joint.
2mm panel gap on a 15~ year old car...uhoh lol
Who could even notice 2mm other stuff sounds fair enough though. Panel beaters would have given zero fks they are useless pricks
Edited by alr33x
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
