SO car was written off but not put o the register..seems strange.
Repairable Write off...
Cheaper for just car insurance to do a write off payout than fix it (properly).
Thus why this sale is clearly dodgy, there won't be a lot of change from $9,000 o.n.o. if it was fixed properly.
I think it doesn't have to be on the register if the car's over 15 year old?
That could explain why it isn't on the register...
WOOOOOOTTTTT MY CAR IS READY!
Time to go to the panel beaters and pick it up... Need to get there in under 50 minutes or the place will be shut... Waiting on a taxi to arrive now *impatient*
I've already called him saying I'm interested... Waiting on a call back... Will go and see it on my way home if I can.
Called him again just before... I'm going to go see it tomorrow... with Matt...
Shall record the encounter for the wasteland lulz
So... my car had a camry reverse into the middle of the passenger door.
It went into the AAMI assessment center on Tuesday Morning last week (19th)
It was getting a new door, and bring resprayed at a place Monash Car Center on Princess Hwy
I get the phone call that it ready to come pick up tonight.
Went there to go pick it up and it all looked good. the paint colors matched and all was well.
Car was locked, so couldn't open the door.
Accepted the car, drove it home and on the way I noticed a "few" issues.
They've swapped the inner door panel, speakers, glass, etc into the new door. The tint on the glass is scratched quite badly and is peeling (like inch long sections peeling off)
The power mirror does not function at all.
The power window functions intermittently, I'm thinking a wiring connection issue.
The panel gaps are different from the top to the bottom of the door, it varies by more than 2mm from top to bottom.
Letting the door swing shut by itself, it stops with 10cm to go.
Once fully closed, the top of the window looks to be about 1cm lower than it should be, so it doesn't go into the slot where it should go, instead it hits the bottom of the fat rubber bit.
Honestly, how the f**k can a place f**k it up so much... *sigh*
Gonna call JCI tomorrow and rip a new arsehole out of this joint.
2mm panel gap on a 15~ year old car...uhoh lol
Who could even notice 2mm other stuff sounds fair enough though. Panel beaters would have given zero fks they are useless pricks
Edited by alr33x
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
