A45 AMG confirmed @ $74, 900 for September. 6.9-7.1L/100km and the 0-100 dash in 4.6 seconds...
EDIT: The Japanese ad had me convinced anyway...
A-a-ron get me one pls.
Edited by kaitoukid
for the myriad of things you are having done it would be a LOT cheaper to go elsewhere....
im more after a place which can do everything at once - tune + 100k service + install parts
racepace did an awesome job last time i took it there and is much cheaper than another place ive been to a few times, also their previous quotes were pretty low from what i remember..
anywhere you would recommend?
SHEES! where dod you used to have it serviced? Nissan Australia? :P
GT hyper and the Trent to tune...
their quote for my engine conversion was HALF that of racepace... HALF... I have been going there religiously since
ahah i used to go to le mans automotive in templestowe
damn okay half would be a big difference!
might check them out :P
was originally going to see if trent could do the tune
ty
Edited by bluejeans
ask for lin and tell them hamish from SAU sent you.
its a dirtly little shop lol... but they take care of the cars and have done nothing but 100% perfect work on my car every time
Strangely enough, I find the dirty little shops always to be the best ones to go to, and the ones that take most care.
Scott's shed for example, there is shit everywhere. But wouldn't go to anyone else..
I called up Lin once, booked in my car to install the new gear... Injectors, AFM, ECU, Turbo, Fuel pump etc...
Price was good as well, the only problem that he was really bogged down with work in the time span that I needed it to be done, it was going to take 2 weeks to get it done.
So I ended up doing it myself at home over the same timespan, just working a few hours each night... Learnt heaps and somehow didn't screw anything up :D
Wouldn't suggest that route to install all your new fruit on the GTR though, would be very ambitious indeed. (But would save a bucketload for sure)
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
