There was a bloke at High School who we always gave crap to because he drove around in his mums car and pretended it was his own.
We'd call it the "Baby Blue Honda Jazz"... and without fail he'd always yell "It's ICE BLUE!!!!" and when we gave him crap about it being auto, he'd say that autos were faster at the drag strip... *shakes head slowly*
Hmm you went to school with birds didn't you?
lol you go missing on the regular anyway...
Congrats dude! Take me for a ride? Still waiting for our red 86 to come :D
Yeah you're right, I do. Not as much time for forum whoring these days. Cut right back.
And sure, if you're there at the Dyno Day/Renewal Day on Sunday I'll be there. It'll be a sedate ride though, will be running it in.
And wow, fatherhood has turned Hamish into an angr(ier) man! It's okay, I won't try and infect you with my auto driving ways. Hey I had/still have auto FWD's and I'm female. All the stereotypes at once.
Avatar___All_My_Single_Ladies_by_Acaciat
Edited by llama_au
do people still run in new cars?
Definately subscribe to this school of thought. Beat on dat engine yo!
What uni man?
SAU Daytona meet.
Monash Clayton man. Although majority of that time was when I was in first year. IN for SAU Daytona meet though, brush back up on dem drift skillz. + I'm always at Uni :P
Realised by 'hard' I think I meant 'advanced'. Ain't nobody got time for Expert :P
Edited by kaitoukid
Yeah I would probably go and beat on a new engine, all the mechanics do it when they rebuild engines nowadays too
Worst case scenario is it needs a rebuild, and on a BRZ that can only include forced induction :P
Yep, warm up your engine and then rev it out (dont limiter bash though)
That's what I did with mine and the tuner said it was making some really good power standard and I must of worn engine in well
Just drive it as you would if you bought it second hand...new cars are designed with the lowest common denominator in mind, who wouldn't consider running in periods. They couldn't afford to warranty new cars if they would break from driving it with a bit of stick. Think the engines are fairly run in / tested from factory anyway.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
