lol ive thought about it but too scared!
im hoping to do a rebuild at the start of next year and go forged so even if a cylinder (or more was down) will have all supporting mods for when that comes (at worst case!)
so thats pretty much everything - still waiting on hks front pipe and moonface tie rods have been delayed (again) for another month, so waiting for some oem tie rods for the mean time.
  • Like 1
*drools*
Best feeling looking at all the parts you've accumulated before they go into the car....:
what happened with your r33 in the end hamish? did bearing go or just change to evo for new born?
engine 1 spun a bigend... engine 2 (the good one) has gone to that great big street-race in the sky
basically I sold it to some dude that lives in bundaberg, he had it for 3 days and then apparently "backed out of his house into an s15 that was street racing"
then bundaberg flooded
yeah it feels good apart from constantly stopping my doberman from trying to grab parts and run around the house with them :domokun:
ahh see this i didnt know..
so was a write off im guessing?
Edited by bluejeans
Project MU B-Spec Pads?
You should also get a Cusco Brake Master Cylinder Stopper too.
What brand water pump is that?
You should have at least bought Tomei Cam Gears or Racepace can modify your existing ones :laugh:
yeah bspec pads - used them on my gtst and have them on the front of the R - needed some for the rear :P
cusco brake master cylinder stopper is something id like but i guess ill do that when i have some $ to spare lol
its a nissan water pump :P
i was thinking of staying with standard and getting racepace to modify, but dat purpleeee mang!
Ferrets typically have brown, white or mixed fur and are around 51cm in length and weigh around three pounds. Toy poodles are around 25cm tall and weigh around four kilograms.
Dem measurement units
Think I've got brake master sitting in garage somewhere, missing the flat bit thingy (to the master) and it's been painted black - peeling though.
Can look for it if you're keen.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
