Think I've got brake master sitting in garage somewhere, missing the flat bit thingy (to the master) and it's been painted black - peeling though.
Can look for it if you're keen.
nah all good man - though maybe in a month or so ill get back to you about that :P
yeah bspec pads - used them on my gtst and have them on the front of the R - needed some for the rear :P
cusco brake master cylinder stopper is something id like but i guess ill do that when i have some $ to spare lol
its a nissan water pump :P
i was thinking of staying with standard and getting racepace to modify, but dat purpleeee mang!
Nissan N1 Water Pump?
Lighten your wallet just for purpleeee coloured cam gears :laugh:
You must earn a bit :P
http://www.ferrarichat.com/forum/288gto-f40-f50-enzo-laferrari/277182-what-best-turbo-upgrade-f40.html
discussion on what turbo upgrade will be best for my F40... featuring such gem's as:
  • Alot of people go with ball bearing units now
  • Ferrari themselves do the best upgrade for the F40. At least I know they used to. You give your F40 to them and they upgrade to turbos to larger ones which ups the power from 478 HP to 600 HP. Top speed rises to 220 MPH. Send Ferrari an email to see if they still do it.
  • The most popular larger turbo upgrade. Garrett "roller bearing turbos"
  • he original owner bought the parts for his F40 racing projekt in Italy and had it converted at a local specialist. Would be also my way to go for more performance on the F40.
  • Up the boost to 2 bar and you'll see 600+hp
  • I have yet to see any aftermarket upgrade that works better than the factory turbo's.
i may infact read more threads
And he still owns, and has the money to mod an F40.... While you're reading about it :)
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
