i'm armored all the time when i traverse burwood hwy.
can't stab a car. and burwood is still a lot better than coburg.
they could be the kents that entered my garage and stole my fishing bag. though not sure why they would want my fishing bag.
Farkin morons, really worth killig someone over a few dollars?
How stupid do you have to be to hang around the area afterwards.
If Judge Judy has taught me anything, its that stupid people somemtimes do stupid things with some kind of backstory.
Cousins aunties step-brothers mothers dog probably borrowed money a while back, or stepped on someones shoe or called someone a slag.
Anyway point is, if there was some sort of personal involvement or the victim recognised them from kindergarten or if it was some sort of vigilantism (sp) the news/police report isnt going to mention it.
Forced break-in of elderly lady? sure, probably pretty straight forward.
Man stabbed in a supposed mugging and the muggers not taking anything and then being caught within 24 hours? theres probably more to this.
You wouldn't to happen to have all the part numbers for the Neo heater, coolant hoses and thermo stat would ya? :D
Can do, are you gonna be running an aftermarket oil cooler though? If you are it might pay to delete the factory heat exchanger while the engine is out. NA heater hoses clean it up a lot under the plenum and gets rid of a heap of potential leak points.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
